3L 6spMT Accord - turbocharger & injectors
Old May 26, 2007 | 01:30 PM
blackdragon33's Avatar
blackdragon33
Default 3L 6spMT Accord - turbocharger & injectors
I drive an '04 3L 6spMT Accord coupe EX. I am currently installing a Garrett T3 with the works, (intercooler, BOV, wastegate, emanage ultimate, etc) but I am trying to find out what the stock injectors are rated at, (350, 400...?) My acheivable goal is to run 550's, so I can comfortably run 400hp under 7-8lb boost. I am looking for stock injector numbers, to know what I can temporarily run, (I am assuming 5lb boost on stock). Any advise on the injectors, or anyone who has run boost on this car, tips appreciated!
Old May 26, 2007 | 09:50 PM
Misa's Avatar
Misa
Pic Whore
there are very few 7th gen V6s with turbo since the stock headers are welded on.
Old May 27, 2007 | 06:24 AM
flyromeo3's Avatar
flyromeo3
Im sure he knows that since, he got "the works"
Old May 30, 2007 | 05:52 AM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
I've scene E-shift Pro-cats however on the TL forums for the same gen. Couldn't you simply mount a turbo the same way with a modified pro-cat.
Old May 30, 2007 | 01:33 PM
blackdragon33
Default No cats
I am making my pipes custom to fit my electronic exhaust cutouts....(control backpressure for the turbo). E-manage ultimate will take care of the 02 sensor readings. I've seen a red 6th gen with a roots-type blower....a company called comptech (no longer exist). I think he ended somewhere around 250hp...(bad memory). But starting at 250 for 7gens, this platform can hold 400hp on a T3 under 7-8lbs. I haven't seen it yet, but someone's gotta do it!
