Acceleration hesitation
Old May 25, 2007 | 11:38 AM
ssameer2601's Avatar
ssameer2601
Default Acceleration hesitation
Hi all
I have a 99 Accord non vtec with a few annoying problems. sometime at statrup the car hesitates as if the fuel has ben cutoff for a second or two especially after cold start. then there is the hesitation especially below 2500 rpm which is annoying while overtaking. Also i have noticed that the car accelerate rapidly after 2500 RPM as if i have pressed the pedal more and then the speed increases rapidly. And lastly the car vibrates badly at idle enough to keep you awake when feeeling sleepy. The following geniune parts have been replaced with minimiun results. spark plugs, distributer coil, plug wires, distributer roter, ALL ENGINE MOUNTS, fuel filter, pcv valve, air filter, map sensor, timing belts and bearings. Also cleaned out the throttle body and the iac valve. Please help
Thanks a lot in advance
Old May 25, 2007 | 12:03 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Clean the EGR
problem solved
Old May 25, 2007 | 12:46 PM
ssameer2601
No egr cause its a GCC spec.
Old May 25, 2007 | 12:52 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Your car isn't going to jolt forward below 2500RPM.
Old May 27, 2007 | 06:34 AM
flyromeo3's Avatar
flyromeo3
torque probably wont kick in until 3k.
