tac problem effecting transmission 95 accord
Old Apr 6, 2007 | 07:30 AM
tjash1182's Avatar
tjash1182
Default tac problem effecting transmission 95 accord
I have a 95 honda accord v6 automatic with 130,000. My tachometer jumps like crazy from 0 to actual rpm. When it starts doing it bad my transmission starts acting up as if it were trying to shift gears but doesn't actually shift. It will only happen when i have it in D4. It won't happen during hard excelleration. Not sure if it is related but the odometer doesn't work. Any suggestions?
Old Apr 6, 2007 | 09:02 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
So if you're driving 70 mph, all of a sudden the rpm's will jump from 0-rpm out of no where?
Old Apr 6, 2007 | 09:47 AM
fstop128's Avatar
fstop128
its probably your vehicle speed sensor. if not that then your ignitor module. do a search on the vehicle speed sensor. u can easily replace it yourself.
Old Apr 6, 2007 | 09:55 AM
stereo's Avatar
stereo
the tach problem on the 95-97 V6 accords are usally caused by a bad ignition coil.
