How do i push brake piston back in?
Old Mar 24, 2007 | 09:04 AM
dazco's Avatar
dazco
Default How do i push brake piston back in?
I haven't replaced pads on a car for a long time, and last was an early 90's model. I usually used a C clamp to push the piston back in when installing new pads. However, on my 2004 accord i can't seem to budge it. I removed the master cyl cap and even tried loosening the bleed screw. But i cannot budge it. Any tips for what i need to do here? thanks.
Old Mar 24, 2007 | 09:11 AM
Shockwave895's Avatar
Shockwave895
you could try getting some brake caliper spreaders. I've never had a problem using them.
Old Mar 24, 2007 | 10:13 AM
Hondamugen103's Avatar
Hondamugen103
have you tried using a rubber mallet or an air compressor?
Old Mar 24, 2007 | 10:34 AM
dazco's Avatar
dazco
Thanks. That did it ! The C clamp would have worked but the caliper didn't offer any sort of place to anchor the other end very well. But the piston was a bit stuck. I bought a cheap $8 spreader and though the piston was stuck and took a bit of strength it finally gave and turned smoothly as it went in easily. I've always used a c clamp and didn't even know about spreaders for brakes. I was thinking of looking for a spreader of some type but didn't realize they made a cheap brake specific one. You've done your good deed for the day, thanks much.
Old Mar 24, 2007 | 11:46 AM
Shockwave895
NO prob..glad to help
