transmission upgrade
Old Mar 11, 2007 | 09:21 PM
Atom Legion's Avatar
Atom Legion
Default transmission upgrade
well, i found out that my speed sensor was bad, so i replaced it, then the tranny started downshifting very roughly, so i posted a thread about it, i was told it may be an electrical problem, so i disconnected the sensor, went ok for a week or two, and my tranny clanks hard when it upshifts, i drove it home last night and i was stuck in 2nd for the longest, then it went to third, never went to forth the whole time, if anyone has any suggestions, by all means, fire away, however, i'd also like to know what, if any "slapstick" tranny will fit for my 91 accord sedan, cuz i'd rather have one of those, if not, so be it, i'd appreciate any input, thank you.
Old Mar 13, 2007 | 09:50 AM
Atom Legion
ok i went ahead and put my old speed sensor back on, now it shifts when it should and doesn't when it shouldn't, but now it absolutly refuses to go into 4th gear, so.... i'll take any input on that one
Old Mar 13, 2007 | 09:56 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
5-speed swap and learn to drive a car the way it was meant to be driven:dunno:
Old Mar 13, 2007 | 11:42 AM
sibiryk's Avatar
sibiryk
Check 4th gear solenoid.
Old Mar 14, 2007 | 07:14 AM
shane21085's Avatar
shane21085
Do what i did get a JDM 5 speed manual transmission put a stage 2 clutch on it, Limited slip differential (LSD), lightened flywheel and a short shift, then youll be set. Total coast after everythings done around 2500$ USD. Or get a remanufactured honda certified tranny for about 2000$ and let the dealership put it in for about 1500$ its your call..
J
