Quick ??? about meter lens replacement.
Old Mar 5, 2007 | 10:49 AM
xcitor's Avatar
xcitor
Default Quick ??? about meter lens replacement.
Just wondering how hard it is to replace the meter lens on a 2003 accord ex v4?
Also if someone has instructions on how to do so, that would most certainly help as well.
Thanks for any1 who answers.
xcitor
Old Mar 5, 2007 | 10:57 AM
meter lens?
like the plastic that goes over your gauges?
Old Mar 5, 2007 | 11:02 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
What do you mean by "meter lens"? You mean gauges or clear plastic over the gauges?
Edit: Ya beat me to it.
Old Mar 5, 2007 | 11:28 AM
xcitor's Avatar
xcitor
Yeah the hard plastic above the gauges.
Thanks
xcitor
Old Mar 5, 2007 | 01:23 PM
v6_accord_jerz
Stupid Power Ball
Thanks
xcitor
Should be pretty simple, i'm assuming it's probably just held in by a couple of screws then just carefully remove it and replace. Why are you trying to replace it, did you crack it?
Old Mar 5, 2007 | 08:03 PM
k.heiner's Avatar
k.heiner
Remove the two screws up top.
With the steering wheel tilted down pull at the bottom gently, there are 2 clips. Towards the middle there are two hooks. The upper part should pull out with a gentle tug. It should just slide out...
Old Mar 5, 2007 | 08:49 PM
Misa's Avatar
Misa
Pic Whore
there are 2 more screws that are exposed when the wheel is tilted down.
