01 Accord V6 Spark Plugs
Old Feb 27, 2007 | 05:30 PM
keng's Avatar
keng
Default 01 Accord V6 Spark Plugs
Anyone with experience with changing the spark plugs on 01 Accord V6 engine? The front spark plugs looks like it's easy, however the back is the problem. Thanks!
Old Feb 27, 2007 | 06:32 PM
Fuse's Avatar
Fuse
Just get a set of extensions and a spark plug socket.Ya its a pain but not very hard just time consuming.Use the recommended plugs usually ngks and tork to 13 foot pounds.On a 01 i thing you use non plats(plats have a little shaft electrode non plats are flat and have a split in the electrode).
Old Feb 27, 2007 | 08:05 PM
simplyredvw's Avatar
simplyredvw
It's pretty easy. Just make sure you use the factory NGK platinum plugs that are called for with your vehicle.
Old Feb 28, 2007 | 07:03 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Pretty simple, all you need is a set of extentions, patience, and some time. Make sure you tighten it to 13 lbs/ft also.
