Tips for 95 Accord Headlight ASSEMBLY Replacement
Old Jan 26, 2007 | 06:13 AM
joelpfas's Avatar
joelpfas
Joel
Default Tips for 95 Accord Headlight ASSEMBLY Replacement
Anyone have any tricks for replacing the Headlight Assembly (not the bulb) on a 95 Accord. I pulled one of my studid moments in replacing a bad bulb and to keep the story short, ended up with a broken halogen bulb inside the assembly. The light is working now with a new bulb, but the bad bulb is bouncing around in there.
Help.
Old Jan 26, 2007 | 06:16 AM
remove the front bumper to expose the 10mm bolts holding in the housing.
Old Jan 26, 2007 | 07:07 AM
AJē06's Avatar
AJē06
Then proceed to removing the ... bulb u broke inside....
Old Jan 29, 2007 | 08:45 AM
mycb7com's Avatar
mycb7com
I've never done that myself.... Hopefully you figured it out.
Old Jan 29, 2007 | 09:39 AM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
If its setup the same way as my 96, remove the front bumper, and there will be 10mm bolts you need to remove. Facing the car for the left headlight, it will be almost directly below the housing and slightly to the left. Opposite for the right side. There are also 2 (?) 10mm bolts on the tops of each headlight.
