Cost of Low Compression
Old Jan 7, 2007 | 10:10 PM
dleccord's Avatar
dleccord
Default Cost of Low Compression
when a cylinder has low compression, what's the likelihood that i need new pistons? and anyone with experience, how much did it cost you to get your compression back in good range? thanks
Old Jan 8, 2007 | 08:20 AM
sibiryk's Avatar
sibiryk
First you need to find out what is the cause of low compression.
Remove spark plugs and pour a little oil inside of cylinders and measure compression again. If compression increases than you should check pistons-rings part. If compression remains on the same level than you should check valves (cylinders head).
Old Jan 8, 2007 | 10:08 AM
dleccord's Avatar
dleccord
okay. so how much am i looking at most if i were to replace the rings per cylinder and a valve job per cylinder? to get it back to oem and running of course.
