my 93 accord is overheating?
Old Nov 24, 2006 | 03:47 PM
1993 accord's Avatar
1993 accord
Default my 93 accord is overheating?
i got a 93 honda accord and it was running good till yestrday it started to overheat and somking all this white smoke it looks like it coming from some where near the crack shaft but im not to sure i also found one of my spark plug wires cracked and was not in all the way so if any one can help? thanks
Old Nov 24, 2006 | 07:55 PM
Fuse's Avatar
Fuse
Check the coolant level first.Bad cap?.Leaking radiator?.Wash the engine down with water(don't hit the dizzy).Start it up and see if you can pin point the leak.Don't let it over heat.Just replace all the wires.
Old Nov 25, 2006 | 07:19 AM
gulfview's Avatar
gulfview
Also check for cracked and leaky hoses and for loose hose clamps all over the engine compartment. Do not add cold water to an overheated engine, so you wont crack something.
Old Nov 25, 2006 | 08:35 AM
mycb7com's Avatar
mycb7com
The cracked wire could have just been because its old. I would check all the radiator hoses and then change the thermostat, and drive the car as little as possible until its fixed.
