94 Accord Cooling fan problems
Old Nov 24, 2006 | 01:02 PM
pelonid's Avatar
pelonid
Default 94 Accord Cooling fan problems
Can anyone explain how to bypass the temp relays on the cooling fan and wire it so that it comes on when the ignition is on. The A/C cooling fan turns on when it should but the other fan will not start.I have tested it with a 12V power supply and it works just fine,all fuses are good even swapped relays and it still wont work ? Thanks
Old Nov 24, 2006 | 03:09 PM
simplyredvw's Avatar
simplyredvw
Why don't you check the fan switch before you rig it up "ghetto style"?
Old Nov 24, 2006 | 03:31 PM
pelonid's Avatar
pelonid
Default cooling fan
Where is the fan switch located thermostat housing , head, radiator ?
