95 lx not starting help
Old Nov 19, 2006 | 03:23 PM
ali7up's Avatar
ali7up
Default 95 lx not starting help
when i am driving normaly and i turn on the heater, after a while the engine light comes on and the car stops, if that doesn't happen, when i turn the car off it does not start up for another 10 min. it keeps showing the engine, srs, oil, etc light and doesn't start, help advice now hat could be wrong thanks
Old Nov 19, 2006 | 06:05 PM
Fuse's Avatar
Fuse
what is the code?do you know.All your lights will lite up is the engine dies.IF you turn on the heater it sounds like the main relay thy usually fail hot.When thy fail you loose fuel psi.
Old Nov 20, 2006 | 05:00 AM
ali7up's Avatar
ali7up
the battery and the oil light come on before it shuts off, but when i run cool air the car starts perfect, once i turn it into hot air the car will not start
Old Nov 20, 2006 | 05:36 AM
ali7up's Avatar
ali7up
i did the check light test and the code came out to be 15 Ignition Output Signal missing or defective ignition output signal what does this mean and how can i fix it thanks
Old Nov 20, 2006 | 04:04 PM
Fuse's Avatar
Fuse
i would go with an ignitor its under the distributer 4 wire 2 screws.The battery light would indicate a bad alternator or loose battery cable.Its strange how you heater control makes it start or not start i have never run into that before.
