Fog Light Installation Help
Old Nov 19, 2006 | 02:37 PM
accord2fast09's Avatar
accord2fast09
Default Fog Light Installation Help
I am installing Aftermarket Fog lights in my 03 honda accord ex v6 coupe and ran into a problem, there is a wire that i dont know where it goes i have looked everywhere online and pdf files and still have no idea where it goes. Can any one please help.this is a blue wire that is located under the Steering wheel inside. thanks
File Type: jpg
Last edited by accord2fast09; Nov 19, 2006 at 02:40 PM. Reason: FOrgot to put in Model of car
Old Nov 19, 2006 | 07:24 PM
Fuse's Avatar
Fuse
do thy work that just looks like the connector you would use to add extra accessories.
Old Nov 20, 2006 | 02:50 AM
flyromeo3's Avatar
flyromeo3
im not sure if you even use that plug, I would assume the plug would have 3 or 4 connectors.
1 - ground
1- remote turn on
1 - power constant.
Is that what's left over from the install?
Old Nov 20, 2006 | 11:22 AM
accord2fast09
Yes i have connected all the other wires and all that was left over is this blue connector and my light do not work i dont know if it is this connector or i messed up somewhere
Old Nov 20, 2006 | 04:01 PM
Fuse's Avatar
Fuse
see if you have 12v to the power wire on the fog light.
Old Nov 21, 2006 | 12:59 PM
accord2fast09
I finally figured out wut the problem was it was a problem in the fuse box, so the blue connector didnt go anywhere, and also are the Fog Lights Repose 2 get REally Hot?
