Some wrong with my Car Water system Help!!!
Old Oct 22, 2006 | 09:26 PM
Dnguyen242's Avatar
Dnguyen242
Noob
Default Some wrong with my Car Water system Help!!!
I just resonly seen my heat gage go up. and found out there no fluid in my Radiatorand and the Emergence water I put in it. I see that Emergence water shoot up some where in the back of then engine when I stop the car, At this time the heat gage is at the middle. So any Ideal what it is and how much this will cost me to fix if I bring it in to a shop or can I do it on my own with some help form you People. Thank you For you input.
Old Oct 23, 2006 | 07:25 AM
fstop128's Avatar
fstop128
get a haynes manual from autozone. u can start with the easy stuff the hoses and clamps. then move to the radiator. water pump is on the drive belt side at the bottom. the coolant leaks can be hard to find after the car has been running. prices can be below $50 thru $300. u can do the hoses and thermostat yourself some people do the radiator. the radiator and water pump would be the most expensive. get an aftermarket radiator with a lifetime warranty if that is the source.
Old Oct 23, 2006 | 12:07 PM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
first of all, spelling ownz u... pls do take the time to type properly.. took me like 5 mins to understand what u're saying
so, u said u saw coolant coming out from the rear of the engine bay? might be a heater hose or something... if it's at the back, mostly like it's some sort of hose... if u want, bring the car to a shop and ask them to do a pressure test... tht'll tell u where the leak is... once u know where it is, u decide if u wanna fix it yourself or not
Old Oct 23, 2006 | 06:09 PM
Dnguyen242's Avatar
Dnguyen242
Noob
thanks DarkSideAccord. Ok do a pressure test first. hope it not to big a problem!! Thanks I change the Radiator last year. So I dont think it the Radiator or Radiator water pipe. Never tuch the Heater hose and the steam is coming from the back. Hope that dont cost to much to replace. You guy know any good place in Long Beach to do the test. Thank you agian.
