How do I change blinker bulb
Old Aug 25, 2006 | 04:23 AM
T-man's Avatar
T-man
Default How do I change blinker bulb
I have a 2000 Accord v6 EXL. Is there a DIY on replacing the Front Turn signal bulb? My Right one blew out. Thanks.
Old Aug 25, 2006 | 04:42 AM
there's a hole in the fender wall where you can get your hand into.
You twist the bulb socket, remove, replace.
Old Aug 25, 2006 | 04:52 AM
T-man's Avatar
T-man
Is that were the wheel housing / mud guard is? Are you referring to the plastic covering that are held in place by the small plastic re,taining clips. There are seveal of these clips, do they all have to be removed and do I have to remove the wheel itself to get there?
Old Aug 25, 2006 | 06:06 AM
Big AL's Avatar
Big AL
Swollen Member
It's the wheel well liner and yes you have to remove the little plastic clips, not all of them just enough to get your hands in there. You will probably need to turn your wheel so it faces inward to allow better access. Regardless though it's a tight fit to get your hands in there unless you've got small paws. Mine are big and I managed to scrape mine all up trying to replace those bulbs.
Old Aug 25, 2006 | 06:40 AM
T-man's Avatar
T-man
Perfect, thanks for the advice.
Old Aug 25, 2006 | 11:01 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
man i took my bumper and headlight out to replace it......i saw the hole but my hands are too big and wires were in the way:shrug:
Old Aug 25, 2006 | 11:52 AM
mistacee's Avatar
mistacee
Zc powered ED9
Turn the bulb socket, pull it out, push and turn the bulb and glently pull out bulb.
Reverse steps to replace with new bulb.
