strange noise!
Old Aug 18, 2006 | 11:03 AM
abuhun's Avatar
abuhun
Default strange noise!
Whenever I accelarate, I hear a faint "ssssssssss" noise coming from under the hood. I never heard anything like that before! And this only happens when I accelarate, so if I take my foot off the gas pedal, I don't hear it.
It's making me think that it's coming from the fuel system, but I don't know.
I just did a TB + WP job and got all the belts replaced. I thought that was the issue, but that didn't solve it.
Thanks.
98 Accord Auto 4cylind
Old Aug 18, 2006 | 11:06 AM
sibiryk's Avatar
sibiryk
I would check vacum lines.
Old Aug 18, 2006 | 11:20 AM
abuhun's Avatar
abuhun
Default Can you tell me where they are located.
Or from/to where they connect to in order for me to trace them.
Thanks.
Old Aug 18, 2006 | 12:07 PM
fstop128's Avatar
fstop128
their should be a vacuum diagram under the hood on a sticker. or somewhere under the hood. i have a 92 its got a diagram there. could be the belts need to be adjusted, that or a belt driven part could be going out like the water pump or alternator. something with a bearing in it. u mention the water pump is new so that can be checked off the list. a belt tensioner can be noisy.
Old Aug 18, 2006 | 12:10 PM
abuhun's Avatar
abuhun
Thanks. I'll check those out.
Old Aug 19, 2006 | 02:22 PM
JimBlake's Avatar
JimBlake
Don't get your hopes up. Vacuum leaks are most noisy when idling. When you're accelerating, the vacuum isn't nearly as strong.
But... Look for a bad check valve on the big vacuum hose for the brake booster.
Old Aug 22, 2006 | 12:28 PM
abuhun's Avatar
abuhun
Default Here is an update
I checked the lines, and they look OK.
I noticed the noise doesn't come when the car is in Park, but as soon as I engage the gear, it comes up.
I tried listening to it, and it's coming somewhere near the firewall. I just can't figure out where.
If the noise gets louder, I will have to do something about it.
Old Aug 22, 2006 | 03:16 PM
JimBlake's Avatar
JimBlake
Have a friend start & stop the car while you listen under the hood; maybe that way you can narrow down the location better.
The brake booster would sound like it's coming from the firewall.
