errrrrrr... help.?
Old Aug 8, 2006 | 10:27 AM
mkv's Avatar
mkv
Default errrrrrr... help.?
ok so my uncle gave me his 95 accord a few days ago.it's got a sunroof and i think it leaks because the fabric on the roof has moldy spots and parts are peeling off. i want to replace the fabric and im wondering how much it's going to cost.i really do not know much about cars so any help will be appreciated.thanks.
Old Aug 8, 2006 | 12:06 PM
noscope101's Avatar
noscope101
Eg_93_CPE
Well it depends on the leak, that should be the frist thing to adress not the fabric, but if its moldy then you might as well get a new head liner after you fix the leak, could cost any where from 200-600, depends on the job and person doing it
Old Aug 8, 2006 | 12:26 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Just take it to a shop, it's not easy to do.
Old Aug 8, 2006 | 01:42 PM
fstop128's Avatar
fstop128
true. a friend of mine had an old grandam that leaked. it couldnt be fixed because of the rust. it looked like surface rust but it was deeper. would cost too much to cut out the roof and replace it.
Old Aug 8, 2006 | 06:43 PM
VPUPPY's Avatar
VPUPPY
You could always get a headliner from a junkyard. I would pull it apart if you can, and find the leak. Could be a clogged drain tube.
Old Aug 9, 2006 | 06:48 AM
Johar's Avatar
Johar
There is no point in replacing the fabric until you fix the leak. Check the around the sunroof, anything noticable as far as rust? or damaged seals?
