93 accord overheating
Old Jul 14, 2006 | 12:27 PM
usc5678's Avatar
usc5678
Default 93 accord overheating
I have a 93 honda accord. I recently drove on a three hour trip in my accord. While I was driving there werent any problems, but as soon as i got to a stop the engine started heating up. Also, my AC would work on and off the entire trip. Should I replace my front two fans? Is it my thermostat? What is wrong with my car, i would like to fix this myself since I dont have much money. If you know what this problem is, can you tell me how and what I need to do to fix it. THanks!
Old Jul 14, 2006 | 12:29 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
How much did it overheat? Do you have a Check Engine Light?
Old Jul 14, 2006 | 01:22 PM
usc5678's Avatar
usc5678
it will overheat all the way up to the red line and I do have a check engine light, but the light did not come on. I was told that the two fans in the front are not working and that while I am driving enough air flow is cooling the coolant. I just checked and the fans will not come on regardless if the A/C is on or if the engine is hot. they will not come on period. I was told they are supposed to come on with the A?C regardless of the engine temp. The AC does not work either.
Old Jul 14, 2006 | 01:26 PM
F22B Prelude
Rachel Bilson
Don't drive the car anymore, you'll run the risk of warping the head.......Find out what the Check Engine Light is.......Check the fuse for the fans/also check the relay.
Old Jul 14, 2006 | 01:33 PM
usc5678's Avatar
usc5678
how do I check the fan's relay? Are the fuses and relay in the same place? Also, how can I hotwire the fans to make sure they still work and I dont need to replace them? thanks
Old Jul 14, 2006 | 01:39 PM
F22B Prelude
Rachel Bilson
Check your fuses first...and see what the CEL is then get back to me.
