SeRIOUS PROBLEM!!!!!!! NEED HELP FAST!!
Old May 29, 2006 | 11:36 AM
BigVic4545's Avatar
BigVic4545
Default SeRIOUS PROBLEM!!!!!!! NEED HELP FAST!!
WHat up guys i have a 94 accord ex 4 door...i got out of work put down all the windows and sunroof...so when i get on the highway i notice that my speedometer and Tach needles arent moving while i was driving and the windows and sunroof wouldnt close...i am very confused...i was thinkin it could be some fuses but im not sure...any suggestions are highly appreciated..thank you.
Old May 29, 2006 | 12:20 PM
95LSTypeII's Avatar
95LSTypeII
I know your speed sensor will affect the tach/speedo, but it's apparent there's something else going on if your windows wont work.
Check fuses/relays before you do anything else.
Old May 31, 2006 | 10:34 AM
Baco95's Avatar
Baco95
that just ain't baaalla!
Maybe it’s an alternator issue? A shop put a bad one in my car one time, but I drove over 50 miles on just my battery before the car finally died.
Old May 31, 2006 | 11:27 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
^^^^take It For Baco!!!!
Old May 31, 2006 | 06:49 PM
stereo's Avatar
stereo
sounds like you got somthing going on more then a fuse but it won't hurt to check them (all) if the tach and speedo ,power windows,sunroof... you can check a few simple things like grounds ignition switch ECT.. but it sounds like somthing for a pro.
Old May 31, 2006 | 07:26 PM
BigVic4545's Avatar
BigVic4545
Thank u guys...it was a simple 7.5 amp fuse...i appreciate the comments.
Old Jun 1, 2006 | 06:03 AM
Big AL's Avatar
Big AL
Swollen Member
Whoa! You have all those things on a single 7.5 amo fuse? No wonder why it blew. Maybe you could operate each one independently but I bet if you try operating all those things at once it'll blow again. Maybe the fuse is not the correct size?
