Air Ride Systems
Old Sep 23, 2002 | 06:23 AM
EliteBob13's Avatar
EliteBob13
I nearly wet myself!
Default Air Ride Systems
I want to put some air cylinders on my '99 Accord and I was wondering if anyone had suggestions on a brand or where to by? Any technical suggestions would be a big help. Lastly does anyone know if these suspensions cyclinders have a minimum working temp? I live in South Dakota and the weather can dip below -40F with wind chill.
Thanx,
Bob
Old Sep 23, 2002 | 11:11 AM
accordv6silver's Avatar
accordv6silver
wat is air cylinders & how do these work? how much is it also?
Old Sep 23, 2002 | 11:13 AM
EliteBob13's Avatar
EliteBob13
Air cylinders are for you suspension and helpful in laying some frame.
Old Sep 23, 2002 | 11:15 AM
accordv6silver
are they like shocks then?
Old Sep 23, 2002 | 11:18 AM
EliteBob13's Avatar
EliteBob13
To be honest I am not sure what part(s) of the original suspension they replace as I am just learning myself.
Bob
Old Nov 26, 2005 | 02:32 PM
ABUCIV's Avatar
ABUCIV
sup, i will answer your questions. an air cylinder replaces your springs and shocks, most are bolt on kits which bolt stright up to your struts. runnin cylinders your need a air tank, compressor and if you want your car to go FBSS(front back side side) your need valves. also gauges and switch box.
i have a full air cylinder kit in my 92 civic, im runnin the cylinders of two 3gallon tanks, a 380c compressor and 8 1/2 valves and 1/2 lines. it is very fast and cost me $3,000 but i live in New Zealand so would be alot cheaper for you.
Old Dec 12, 2005 | 03:27 PM
shavedaccord's Avatar
shavedaccord
yea my kit was only like $1400, ive got 8 smc valves, 3/8 lines, 5gal tank, and viar 450 compressor. make sure you get quality cylinders.
Old Dec 14, 2005 | 10:03 AM
accordsir86's Avatar
accordsir86
they look pretty sick on accords if you have the right wheel, tire, kit setup. good luck on that project, post pics when your done.
Anthony
Nov 6, 2007 02:25 PM
white_n_slow
Dec 23, 2005 10:52 AM
Dekz
Aug 13, 2004 07:35 AM
