Cylinder Misfire - Possibly running rich
Old Apr 2, 2006 | 08:26 AM
Balrog's Avatar
Balrog
Default Cylinder Misfire - Possibly running rich
I have a 1999 Accord EX with the 3.0L V6 and 136k mi. Here's my situation: Pulled codes P0300, P0302, and P0303. I've just replaced the cap & rotor, confirmed good spark on all plug wires. Some carbon deposits on all spark plugs (Denso KJ16CR-L11, 12k miles on plugs)
Compression
Approximately 180psi on cylinders 1-4 and 6
80psi on cylinder 5
From searching, most of the people with misfire issues replace the cap, rotor, wires, and plugs to start. I think mine are in good shape. I'd appreciate some diagnositic advice before I do any more tinkering or spend any more money. Thanks.
Old Apr 2, 2006 | 06:49 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
I think it's rather obvious you have a compression problem on cylinder #5. You're going to want to buy a Helms or take it to a Honda dealer/good mechanic if you can't do this stuff yourself.
Old Apr 3, 2006 | 08:27 AM
Balrog's Avatar
Balrog
I know that a compression problem with 5 is obvious. But why would I get a P0302 and P0303 instead of a P0305?
Old Apr 3, 2006 | 08:46 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Which cylinder mis-fires are those from...I dont feel like looking it up.
Old Apr 3, 2006 | 09:01 AM
Balrog's Avatar
Balrog
P0300 Random Misfire
P0301 Cylinder 1 Misfire
P0302 Cylinder 2 Misfire
P0306 Cylinder 6 Misfire
Old Apr 3, 2006 | 12:37 PM
98CoupeV6's Avatar
98CoupeV6
Basic troubleshooting: Fix the obvious problems, then see what codes come up afterwards.
Old Apr 3, 2006 | 12:47 PM
F22B Prelude
Rachel Bilson
Try NGK plugs and see what happens.....That #5 Cylinder is prolly throwin your shit out of whack.
Old Apr 3, 2006 | 01:01 PM
98CoupeV6's Avatar
98CoupeV6
Denso plugs are fine. I'm interested as to what is causing the low compression...I haven't heard of a case of really bad compression like that on the J series.
Old Apr 3, 2006 | 02:58 PM
flyromeo3's Avatar
flyromeo3
could the head gasket cause it to leak ?
Old Apr 3, 2006 | 05:07 PM
98CoupeV6's Avatar
98CoupeV6
That's typically the most common cause but unless the heads have been tampered with I dont possibly see why you'd get a heads gasket leak in 136k miles.
