Need some help ASAP!
Old Feb 3, 2006 | 07:10 PM
JeDPhelps's Avatar
JeDPhelps
Default Need some help ASAP!
I am working on a 1988 Honda Accord. The car turns over but will not start, I tried using some starting fluid but still nothing. Its getting spark but Im not sure its enough to start. I was thinking its the coil but I want to test it first. How would I got about testing that?
Old Feb 4, 2006 | 09:41 AM
semyonlibman's Avatar
semyonlibman
Is your distributor turning? If not this is your timing belt.
Do you have fuel?
Old Feb 4, 2006 | 10:06 AM
omaishcars's Avatar
omaishcars
go to some mechanic . ask him to change each part one by one and see what works well . in this way you know whats bad with your car
Old Feb 5, 2006 | 01:52 PM
frankvega93's Avatar
frankvega93
Default need to measure ign igniter
need a ohms meter measue the four slots the measue is a reading between (. to 250) if not replace igniter
Old Feb 8, 2006 | 06:23 PM
pierranchis's Avatar
pierranchis
listen up bro these could be the possible factors..no gas,spark plugs,dead battery or no juice in the battery,or your main relay..i had my mailn relay on my car recently changes because it would not start my car on hot days...thats said to be common on all 98-02 accords around 90k miles
Old Feb 8, 2006 | 06:36 PM
All your posts have been garbage. Last warning.
