bulb replacement on 98 accord ex coupe
Old Jan 16, 2006 | 08:07 AM
hotboy_22's Avatar
hotboy_22
Default bulb replacement on 98 accord ex coupe
I need to replace my low beam headlight bulb on the driver side in my 98 accord ex coupe can someone help me
Old Jan 16, 2006 | 08:14 AM
it's in your owners manual, look there for detailed pictures.
Old Jan 17, 2006 | 01:06 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Wow.
Old Jan 17, 2006 | 02:45 PM
hotboy_22's Avatar
hotboy_22
whats wow for
Old Jan 17, 2006 | 06:24 PM
badtameezboy's Avatar
badtameezboy
Dont worry about the WOW.
Open your hood and pull the white connector down on the headlight, twist the bulb and pull it out. Its that easy. It should be in the owners manual as well.
Old Jan 17, 2006 | 09:30 PM
AccordV6's Avatar
AccordV6
you can here http://www.sylvania.com/ConsumerProd...RG-Results.htm
good luck
Old Jan 18, 2006 | 04:03 AM
kid018's Avatar
kid018
In the depths of my mind
unplug the connection (push small tab and push down). Once the connection has been detached, twist the bulb about an 1/8 of a turn...you'll feel it unlock. Then pull straight out. If you are asking about the fitting, my low beams are 9006 . I have a 1999 v6 sedan...so it should be the same. Installation is just reverse of above instructions. GL :-)
Old Jan 18, 2006 | 05:49 AM
hotboy_22's Avatar
hotboy_22
its not that easy to get to the headlight
