6th gen low fuel light
Old Dec 29, 2005 | 08:29 AM
jghall00's Avatar
jghall00
Default 6th gen low fuel light
The low fuel light on my 6th gen EX has not been working for quite some time now. I don't know if it's a bulb, or a fuse. Since this is an idiot light, I'm sure there's an individual bulb for it. How would I go about confirming the bulb is the issue, and replacing it? Specifically, I'm not sure which fuse to check, or how to remove the dash to access the bulbs. A bulb on the left side of the dash is also out.
Old Dec 29, 2005 | 08:30 AM
are you sure you're low on fuel? the thing doesn't go on until you're past or dead on "E"
Old Dec 29, 2005 | 09:18 AM
skabone69's Avatar
skabone69
when I got my 6th gen at 40000K the gas light didn't work. still doesn't, no big deal.
Old Dec 29, 2005 | 10:31 AM
jghall00's Avatar
jghall00
I'm certain, as the car has run out of gas twice. Once to confirm a broken light, and once because my wife needed convincing.
Old Dec 29, 2005 | 01:56 PM
aussieaccord's Avatar
aussieaccord
mine has never worked,i know this cos the gauge goes under E and i fill it up the thing takes all but 3 lt of a full tank.
Old Dec 29, 2005 | 03:01 PM
andy2541's Avatar
andy2541
Old Dec 31, 2005 | 02:42 PM
blacknight07601's Avatar
blacknight07601
Sounds like it's a problem with the bulb.
Just replace it
Old Jan 1, 2006 | 01:46 AM
HurricaneHUgo's Avatar
HurricaneHUgo
Some Mexican
Just wondering, how many gallons of gas does a 6th gen accord have when the empty light is on?
Old Jan 1, 2006 | 01:59 AM
94ccordEx's Avatar
94ccordEx
its probably a bulb, or a connecting wire. the only way to check is to open ur gauge cluster thats in ur dash, and check behind the frame. see if the filliment inside the bulb is broken, or look for a burnt out wire.
Old Jan 4, 2006 | 08:40 AM
jghall00's Avatar
jghall00
What is the procedure for removing the gauge cluster?
