96 accord ignition switch
Old Dec 19, 2005 | 05:20 PM
hiddenman99@yah's Avatar
hiddenman99@yah
Default 96 accord ignition switch
my car was stollen and recovered. I now have to replace it's ignitionn switch. I was able to drive it for a while until the sterring wheel locked-up.(while parked). anyway, does anyone have help onreplaceing the ignition switch????????????///
Old Dec 20, 2005 | 06:03 PM
stereo's Avatar
stereo
just tap out or drill out the 2 breakaway screws and take the lock out until you get the new switch
Old Dec 25, 2005 | 11:10 AM
hiddenman99@yah
Default ignition switch/lock
Hey that sounds easy but I din't have a cordless drill. Do you really think I'll be able to knock a punch through it? Are the bolts aluminum or something? What about chiseling the bolt heads off? That is if the metal is that soft!!!
I'll try again tomorrow >>>>>>>>It sucks not haveing my vehical on , hey it's(Especially on X-mass)
Old Dec 26, 2005 | 12:08 AM
stereo's Avatar
stereo
then use a punch and tap on the screw until it's loose then start on the second one as if you take the first one off the second one will bind or tap one loose and try and bend the bracket out just be carefull not to damage the air bag cable thats under the switch.
