auto window not working
Old Dec 10, 2005 | 04:55 AM
hondarocket's Avatar
hondarocket
Default auto window not working
The windows were frozen shut this morning. After letting things warm up for a while I attempted to open the driver's side window. It was still frozen. A while later I successfully open it but now the auto up and down feature is not working.
Any way to reset this? 2005 honda accord ex v6 6speed
hondarocket
Old Dec 10, 2005 | 07:33 AM
cl206's Avatar
cl206
Default Check ur fuse box
Doh! I misread the post. Well if your window doesnt work @ all, try the fuse lol
Look in ur manual and find the fuse that corresponds with the correct window. Its probably shot.
-cl206
Old Dec 10, 2005 | 10:19 AM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
If I remember correctly, if the battery dies or is disconnected on 7th gen Accords, it looses auto window function. The windows will still roll up and down with normal power window control, but the auto function is disabled. To reset it, I think you have to shut the car off, hold the driver's window switch up, and while holding it turn the ignition to run. Continue holding it untill you hear a beep or a series of beeps, and it should be reset.
I don't know if I am 100% accurate on the steps of this procedure, so you may need to contact your dealership's service department. But I do know there is a procedure like this which must be performed to reset the auto up/down function.
Old Sep 20, 2008 | 10:31 AM
MisterPeabody's Avatar
MisterPeabody
Default Auto Window Function Reset
Had the same problem on my '02 CR-V : the auto up / down function quit working after the battery died.
Fastball's procedure worked great! Thanks!
Old Sep 24, 2008 | 08:27 PM
stereo's Avatar
stereo
to restore auto windows turn the key to the on position roll the window all the way down and hold the switch in the down position for 2-3 sec's after the window is all the way down then hold the window switch in the up position until the window closes and release after 2-3 sec's now auto window should work now.
