Help: 1990 Accord EXR Marker/Taillights don't work.
Old Nov 13, 2005 | 11:45 AM
byp494's Avatar
byp494
Default Help: 1990 Accord EXR Marker/Taillights don't work.
Bought a 1990 Accord EXR and everything runs/works great except the marker and taillights. THe headlights, breaklight, signals, reverse lights all work but cannot get the marker/tail lights to come on.
Any suggestions as to what is causing it?
Is there a fuse that just handes these lights?
I found the fuse box under the hood, but for the life of me cannot find a fuse box under the dash...anyone have a pic a detailed location of the underdash fuses?
If not the fuses what else could cause it?
SHould I try removeing all the bulbs and just try one in the back taillight?
Could I connect the tailight to the headlights somehow and run them off those?
Any and all help is appreciated.
Ian
Old Nov 13, 2005 | 08:14 PM
byp494's Avatar
byp494
Update
-The 'Small Lights' Fuse under the hood is fine.
-Verified that the headlight switch on the turn signal arm works (Checked for continuity on the 20p connector on the streering column according to the Helms manual)
Old Jun 20, 2007 | 08:21 PM
STREETS2525's Avatar
STREETS2525
Default taillight out but everything else works
I am having this same problem in my 1990 honda accord lx and I really need a fix please any help cause I am tired of getting pulled over
thanks in advance
Old Jun 21, 2007 | 02:16 AM
nspec_Cd5's Avatar
nspec_Cd5
the fuse box under the dash is located on the driver side kick panel.
look to the left of your brake padel and you will see a little door type of panel w/ a twisting knob. when you twist it 90* it'll come off and the fuses are located inside of it.
on the back of that panel it shows what fuse is where. hopefully that'll be your problem.
if not lets us know
