Wiper Washer - Please Help
Old Nov 7, 2005 | 04:17 PM
snailspeed's Avatar
snailspeed
Default Wiper Washer - Please Help
Does anyone know why the washer doesn't work? I have a full resevoir and when I pull on the switch, nothing comes out. Any fuse or relay I should look at? Thanks
Old Nov 7, 2005 | 04:30 PM
DaNnYsEvEn's Avatar
DaNnYsEvEn
ThInK PiNk!
do you hear the motor powering? maybe the hose that runs to the sprayers is disconnected or something? did you check them?
Old Nov 8, 2005 | 05:38 AM
Deavvaed1's Avatar
Deavvaed1
04 Accord EX V6
I think that problem could be solved by getting some high quality LED washer nozzles. I hear that green works the best.
Before I get blasted.. I am kidding.
If you hear the motor trying to push fluid, then its not a relay or fuse.
If you wax your car and get wax in the nozzles this can clog them up. Try carefully cleaning them out with a pin. You can also aim them that way.
What year is your car, I will try to get you some details as to which fuses to check if the motor is not making noise.
Old Nov 8, 2005 | 03:31 PM
snailspeed's Avatar
snailspeed
My car is a 98 Accord. I don't hear the motor running and all the hoses seem to be connected. There is no fluid coming out of the nozzles. Thanks for your help and I agree the green LED washers work the best!!!
Old Nov 10, 2005 | 09:26 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Im having the same problem, just haven't had the time to check any fuses or relays. For a while one was spraying, but not the other. Im pretty sure both don't shoot now. Im not too concerned about it.
