h22 problems
Old Nov 7, 2005 | 04:15 PM
Sonny's Avatar
Sonny
Default h22 problems
ok, so i've been trying to get my accord running right for a couple months now and still no such luck. here's the setup, 2000 h22a4 motor going into 1995 accord lx that was converted from auto to 5spd. I'm running a chipped p28 with a p13 map (obd1). here are the problems I'm running into, I get codes 3, 7, 16, 21. they are for the map, tps, injectors, and vtec solenoid. problem number 2, when the car warms up fully, the radiator fan doesn't turn on, I jumped the clip to the fan to see if it work, and it does, I can't seem to figure out why it doesn't want to come on and also when it's warmed up it seems to idle at around 300rpm, lastly, I've had multiple opinions about this blake (98vtec), said it might it might be running on only 3 cylinders as it sound like the exhaust has a slight pulse to it. I'm going to get 2 other basemaps tomorrow to see if it is the chip thats bad, and I'm attempting to troubleshoot all the electrical problems, but at this point I've just gotten a bit frustrated and would like some help and opinions from the online gurus. Sorry for the long post, any and all help is greatly appreciated.
Old Nov 7, 2005 | 07:48 PM
Splatch's Avatar
Splatch
bad as hatch
wire harness ground not hooked up?
Old Nov 8, 2005 | 09:46 AM
Sonny's Avatar
Sonny
all the grounds are hooked up.....
