excessive shaking on steering wheel
Old Nov 1, 2005 | 10:30 AM
JDM ACCORD's Avatar
JDM ACCORD
Default excessive shaking on steering wheel
:angry: every time I pass through a street my car shakes so much that if I wouldn't hold the steering hard I would loose control. My car is a 96 Accord Lx coupe. I balanced my wheels already, but my dad says it has to do something with the box where both arms of the car meet. I don't know if he's right, but the car is salvage, do you guys think that as something to do with it? or is my dad right? replies are appreciated
Old Nov 1, 2005 | 10:32 AM
JDM ACCORD's Avatar
JDM ACCORD
Oh I also forgot to say that when I reach 55 mph my car starts shaking excessively until I pass 60mph.
Old Nov 1, 2005 | 12:29 PM
StRaIgHtUp7's Avatar
StRaIgHtUp7
boobies!!!
i had a shaking problem wit my car but only when i sped up...turned out it was bad cv joint...dont know if datz da case wit ur car but just thought i'd let u know
Old Nov 1, 2005 | 02:44 PM
JDM ACCORD's Avatar
JDM ACCORD
thanks but I don't know about that, I changed one of them two months ago
Old Nov 1, 2005 | 09:44 PM
apexivtecaccord's Avatar
apexivtecaccord
ITZJDM
when i changed my axles the longer one needs to have a rubber balencer on it check to make sure it has it i had that happen to me
Old Nov 2, 2005 | 01:55 PM
webie's Avatar
webie
It's probably a bent rim or irregular worn tire. Actually I had the same problem long ago with my 2000 Accord. I tried everything form balancing to alignment. But when I change my rims and tires last Christmas the problem just disappeared.
Old Nov 2, 2005 | 09:56 PM
mycargov6room's Avatar
mycargov6room
maybe your timing is off?
Old Nov 3, 2005 | 12:33 AM
bonestock's Avatar
bonestock
what does timing have to do with this?
my bet is on uneven tire wear.
Old Nov 4, 2005 | 05:09 AM
skip259's Avatar
skip259
or maybe a broken belt in a tire.
happened on one of my older cars. they put the car up, put it in drive and let the tires spin at idle speed, the tire wobbled a bit.
