4th gen front rotor replacement - lower ball joint
Old Oct 9, 2005 | 11:05 AM
Spyfunkr's Avatar
Spyfunkr
Default 4th gen front rotor replacement - lower ball joint
Trying to replace my front rotors, but Im stuck at getting the lower ball joint freed.
Any tips on how to break the lower ball joint loose? I tried a two-clamp puller, but it doesnt really fit right, so it falls off. Tried a big hammer, but since I dont have a lift, its not high enough to get a good swing.
Thanks, Spy
Old Oct 9, 2005 | 11:07 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Special Honda ball joint puller, ball joint puller fork you can buy at any auto parts store + big mallet, or an impact hammer with a forked end will all do the trick. The last one is funnest h:
Old Oct 9, 2005 | 12:05 PM
wedley2's Avatar
wedley2
bboy Wesley West
jack up the LCA, place something hard between the balljoint and LCA (that fills the gap), lower jack...it should pop off.
Old Oct 9, 2005 | 04:00 PM
jschmid's Avatar
jschmid
:werd: That or get a $20 or so ball joint release tool that has the screw lever type action...I have one and it works every time, very little effort.
Old Oct 9, 2005 | 07:28 PM
wedley2's Avatar
wedley2
bboy Wesley West
lol, i have yet to see one of those @ a auto parts store...ill ask next time.
do you know if they work for tierods?
Old Oct 9, 2005 | 07:46 PM
jschmid's Avatar
jschmid
I know, I had to search a while before finding mine at Napa.
Haven't ever tried them on tierod ends yet...but I think Napa actually carries one specifically for them.
Old Oct 10, 2005 | 07:23 PM
MrHankey's Avatar
MrHankey
90 Accord LX 213K miles
If you believe these guys:
http://www.overboost.com/story.asp?id=426
The tool they used to separate the ball joint is sold at Autozone for $10
It is called "Tie Rod End & Pitman Arm puller for Compact Cars"
I just bought one today but haven't had to use it yet (I will in a few days). It does seem a lot sturdier than those pullers with the hinged arms (which I've tried before with no success). Good Luck!
Old Oct 10, 2005 | 09:01 PM
jschmid's Avatar
jschmid
Looks like it could work...it just depends on the design of the jaws...if it's stable, it should work. My hinge type has worked great for me so far, I don't use it everyday, but I've probably popped about 8 ball joints on 4 different cars...3 hondas and even one BMW 325i and so far it hasn't let me down yet.
Old Jun 1, 2007 | 07:08 AM
Spyfunkr's Avatar
Spyfunkr
Ok, thanks for the replies, guys. I was pushed back on this job, but now Ive added UBJs and UCAs to the job. I've also posted to other threads regarding this. Ive been searching for a specific DIY on this year/model (92/Accord sedan) and have found some text on cars that are close.
One question is: Do I have to get the lowers pressed in to the arm?
Thanks, Spy
Old Jun 5, 2007 | 06:34 AM
Spyfunkr's Avatar
Spyfunkr
In the words of Borat "Whoa whoa woowa!" I'll have a DIY up for the other side, but to make it short for now, I had to pull the wheel bearing out of the steering knuckle to get the lower ball joint out. Got lucky on the impact wrench, $28.
Spy
