Camber Washer Trick
Old Sep 29, 2005 | 01:56 PM
jza802k's Avatar
jza802k
Default Camber Washer Trick
I want to change the rear camber of my 2004 accord and have found many places that talk about how to do the camber washer trick. My question is what is the pitch of the bolts that I have to use? I've heard some use 1.25 and other say 1.5, what is the pitch of our stock bolts?
Old Sep 29, 2005 | 03:23 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
and why are we changing the rear camber, out of curiosity?
Old Sep 29, 2005 | 03:53 PM
georgie's Avatar
georgie
i dont think you can do this on a 04 accord. i know you can on a 94-97 since i did it on mine
Old Sep 29, 2005 | 08:32 PM
jza802k's Avatar
jza802k
yeah, I looked at my car a few hours ago and found that the suspension arm is welded onto the chassis and there is no bolt to replace. I want to change my camber because I installed lowering springs and just got some new wheels and the rear camber is noticablely sticking out. I wanted to do the washer trick because camber kits are so friggin expensive. Wish there was an easier way.
Old Sep 29, 2005 | 11:04 PM
wedley2's Avatar
wedley2
bboy Wesley West
you can only do it with accords from 90-97...sell the car and get a cb7...then you can do the washer trick if it makes you feel better.
Old Sep 30, 2005 | 04:45 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
:lmfao: :thumbup:
sounds like dick, just like how i am when i am responding stupid questions.
but that is true.. LOL
Old Sep 30, 2005 | 11:45 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
Do a search, I posted a thread on how to install both styles of 6th gen camber kit, the '03-'06 Accord uses near the same kit, different part number but same style 5 link. You will need to do this to change camber.
Old Oct 1, 2005 | 01:24 PM
georgie's Avatar
georgie
i just bought the ingalls 4 piece kit for my 04
Old Oct 1, 2005 | 01:50 PM
MrChad's Avatar
MrChad
Will the install be a DIY? www.helminc.com for the serv. manual.
Plus the thread of my 6th gen install is nearly the same as well if you need a guide. Just besure to torque everything to spec. 45 ft-lbs. should do ya and you'll be golden.
