Traction Control System
Old Sep 15, 2005 | 12:04 AM
Xcelon619's Avatar
Xcelon619
Default Traction Control System
I have a 2003 Honda Accord V6 and I'm having problem with the TCS coming on. Everytime I press on the brake the TCS warning light comes on. Does anyone have problems with the TCS coming on? PLease help me out.
Old Nov 5, 2006 | 01:46 PM
12guns's Avatar
12guns
my 2003 accord seems to be having the same problem. Anyone seen the ABS and Traction control lights come on for no apparent reason?
Old Nov 5, 2006 | 02:09 PM
Fuse's Avatar
Fuse
the brake switch go bad take it to a dealer and have the codes read i bet is a brake switch failure have fun that part is on national back order sorry the switch is a 4 wire 2 wires are for the brake lights that part is fine so your brake lights still work fine but the other 2 wires are a computer input used for the tcs and the cruise control that part failles and codes up.
Old Nov 5, 2006 | 08:19 PM
Xcelon619's Avatar
Xcelon619
i got the tcs switch change out, and then i had more porblems with the master cylinder. take it to the dealer to have it check out. it get annoying when it keeps coming on. you should still have the mfg. warranty unless you pass the expected mileage.
Old Nov 6, 2006 | 06:07 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Bringing back old threads FTL!!
