tdc sensor
Old Sep 10, 2005 | 01:31 PM
96vtecaccord's Avatar
96vtecaccord
Default tdc sensor
I tested my ecu and it comes back with code 8. I checked online and it says that is my top dead center sensor. I've called several places and they never heard of such a thing. Can anyone tell me what it is? Where it's located? What it looks like? Thanks.
Old Sep 11, 2005 | 02:23 PM
tim3090kc's Avatar
tim3090kc
I believe that the TDC sensor is reports to the ECU when the crankshaft has rotated past top dead center. If the sensor has a problem, the ECU may not be able to adjust the engines timing correctly, causing it to run poorly.
Old Sep 12, 2005 | 02:21 AM
Dak2's Avatar
Dak2
It is part of the distributor.
Old Sep 12, 2005 | 03:58 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
The TDC Sensor determines ignition timing at start-up (cranking) and when crank angle is abnormal.
