Accord Brake Problem
Old Sep 6, 2005 | 01:36 PM
mlambrecht's Avatar
mlambrecht
Default Accord Brake Problem
I have a '96 accord and having a brake problem. The brakes stop fine but while sitting at a red light the pedal gradually goes to the floor. I have checked the wheel cylinders and all are ok, the booster was checked and is ok, and I don't seem to be losing any fluid. Does anyone have any idea what the problem might be? Thank you.
Old Sep 6, 2005 | 03:06 PM
lk21joker's Avatar
lk21joker
AnotherAccordOwner
your brake line might have air in it, ask a mechanic to check.
Old Sep 6, 2005 | 03:37 PM
mlambrecht's Avatar
mlambrecht
Sorry, I forgot to say the brake lines have already been bled, any other ideas?
Old Sep 6, 2005 | 04:49 PM
stereo's Avatar
stereo
sounds like your brake master cylinder is faulty get it replaced asap as it will get worse
one sign is if you look under the master cylinder you will see fluid leaking on the booster but not always .
Old Sep 7, 2005 | 07:35 AM
JimBlake's Avatar
JimBlake
Originally Posted by mlambrecht
... while sitting at a red light the pedal gradually goes to the floor...
That's classic for a bad master cylinder. Usually it leaks back into the reservoir, so you normally won't find any leakage.
Old Sep 7, 2005 | 07:37 AM
I have selective reading problems.
