FAQ: Keyless Entry Remote Programming - ALL MODELS
Old 06-18-2010, 05:00 PM
  #81
sharshera
sharshera's Avatar
Default 1997 Honda Accord SE FOB is not getting programmed.
Hi all,
I bought two used transmitters for my 97 Accord SE and I got the instruction from you guys here as well as from the good guys at
http://www.collegehillshonda.com/art...ticle_41.shtml
I tried it several times and I never hear the car cycling the locks at all.
The FOB were tested by their seller on ebay, supposedly and they should work.
I have the FOBs with FCC IDs as A269ZUA106.
The FOBs when pressed have a very small red led light going on just above the LOCK button. I am not sure what does that mean? Does it mean low battery or it mean it is working?
Any suggestions are highly appreciated.
Old 06-18-2010, 08:53 PM
  #82
sharshera
sharshera's Avatar
Originally Posted by sharshera
Hi all,
The instructions as follows is what worked:
http://www.ehow.com/how_6219012_program-se-keyless-entry-remote.html
Step 1
Unlock all the doors on the vehicle.
Step 2
Put the key in the ignition and turn it to the on position.
Step 3
Press either the lock or unlock button on the remote.
Step 4
Turn the key to the off position and then quickly return it to the on position. Press the lock or unlock button on the remote. Repeat this step three times. You should end with the key in the on position.
Step 5
Press the lock button on the remote. The door locks will cycle once to let you know the remote is properly programmed. Press the lock buttons on any other remotes within 10 seconds to program them as well.
Old 11-21-2011, 01:06 AM
  #83
VTCop
VTCop's Avatar
Hi sharshera, is this your remote?
Mine is like it. Its broken, and I want to buy one of this in ebay, but I dont know if is posible to reprobram.
Its one button IR remote of a Honda Accord TDI (02-1998) SPAIN, with rover motor.
Old 12-16-2011, 06:22 AM
  #84
bibi08
bibi08's Avatar
Default 2005 Accord EX
What would the program code be for a 2005 Accord?
Old 07-15-2017, 09:55 AM
  #85
monatex
monatex's Avatar
I just bought a 1997 CRV for my teenage daughters first car. The owner gave us several keys but no key fob remotes. I ordered a couple online and tried the programming instructions but they car is not going into programming mode. The locks never cycle. When manually locking the car, all the locks but the front passenger door work, that one has to be locked and unlocked manually for some reason. I tried different batteries in the key fobs but still no success. I know I followed the instructions carefully and tried multiple times. Any ideas as to what the issue is? He did remove the factory radio to replace it with a bluetooth one, I read in one thread that the factory radio may be needed for the key fobs to work? Either way, the car was never even entering programming mode as the locks would never cycle. Thanks.
Old 01-17-2019, 05:58 PM
  #86
JDhade
JDhade's Avatar
I have a 2008 Honda Civic Si with a fully functioning key-remote. I bought a second key-remote and set out to reprogram both by the common method cited here and elsewhere. The car refused to enter the program mode (solenoid activation on the fourth key turn/ button press). Any trouble shooting tips for getting the program mode operational (beyond the key turn/button press sequence)?
Old 03-08-2020, 04:41 PM
  #87
accord96jmo
accord96jmo's Avatar
Default 1996 accord lx fob issue
i have tried several different procedures i have found and still cant even get the locks to cycle to indicate it is in programming mode. please help
gagnaccordv6
Accord
5
12-11-2007 03:01 AM
coqueb62
CL, TL, TLX & Vigor
6
08-05-2007 10:43 AM
niebsmich
CL, TL, TLX & Vigor
05-09-2007 08:28 AM
SilvrTL
CL, TL, TLX & Vigor
7
09-13-2005 05:16 PM
Quick Reply: FAQ: Keyless Entry Remote Programming - ALL MODELS
