Check Engine Light
Old Aug 10, 2005 | 06:54 AM
DenverCruiser's Avatar
DenverCruiser
Default Check Engine Light
The light just came on on my 98 V6. The gas cap was tight so that is not the issue. Question: Can I go anywhere that might have the computer to hook up and see what the problem is? Do some places do it for free? I would rather not go to the dearer mechanics if I don't have to.
Thanks.
Old Aug 10, 2005 | 06:57 AM
if you have an AutoZone or Advanced Auto Parts near your house, they'll do it for free.
Old Aug 10, 2005 | 07:21 AM
DenverCruiser
Thanks, thats what I'll do then.
Old Aug 10, 2005 | 08:38 AM
ak3883's Avatar
ak3883
You can also do the paper clip trick and get the code yourself, if you can count
Do a search, there is a link to the forum/procedure on Honduh forums.
Old Aug 10, 2005 | 09:34 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Can you post it here please? I can't remember which pins it goes into. Last time I had to read a CEL from my car I figured it out because two of the pin slots were slightly polished from me jamming the paper clip in there h:
Old Aug 10, 2005 | 09:36 AM
DenverCruiser
Just went to AutoZone.
Got the Code of P1457
"unable to pull vacume in tank"
Gas cap has always been tight. just took it off- got the usual hisssss, so it the cap is still working correctly right?
Old Aug 10, 2005 | 09:55 AM
98CoupeV6's Avatar
98CoupeV6
This is in my TSB thread, AKA the first place you should look when you have a problem
Old Aug 10, 2005 | 10:21 AM
DenverCruiser
Not to be rude but I dont know how to read through that thread. What would it be under? Thank you for your help.
04-004 08/10/2004 Engine Controls - MIL ON/DTC P0107or P0108 Set
00-064 08/03/2004 Body - Deformed Windshield Moulding
98-084 07/16/2004 M/T - Clutch Pedal Noise
02-052 07/16/2004 Restraints - Occupant Detection Initialization
03-088 04/30/2004 Recall - Ignition Switch Key Interlock Defect
88-023 03/19/2004 Battery - Testing Procedure
04-011 02/26/2004 Recall - Throttle Body Air Screw Adjustment
01-009 02/20/2004 Engine - V6 Engine Oil Leaks
98-011 02/20/2004 Keyless Entry - Remote Transmitter Information
04-009 02/17/2004 Computers/Controls - HIM Module Updating
01-023 01/27/2004 Engine Controls - Control Module Programming Procedure
03-073 11/25/2003 Emissions - MIL ON/DTC P0420 (Catalyst Efficiency)
03-073 10/31/2003 Emissions - MIL ON/DTC P0420 (Catalytic Converter) Set
03-078 10/28/2003 Brakes - Brake Indicator Comes ON/Goes OFF
NHTSA03V423 10/01/2003 Recall 03V423000: Ignition Cylinder Inspection/Repair
03-062 09/16/2003 Interior - Seat Belts Slow to Retract
03-034 09/02/2003 Campaign - Seat Linkage Inspection/Modification
98-018 07/22/2003 Drivetrain - Revised CV Joint Boot Band/Installation
00-088 06/03/2003 Brakes - Brake Disc Refinishing Guideline
03-022 05/20/2003 Audio System - Remote Controls Malfunction
00-049 04/29/2003 Antitheft System - Type 2 System Operation/Programming
03-020 03/29/2003 Engine Controls/Emissions - OBD II DTC's & Monitors
03-016 03/25/2003 Engine Controls - Inspection of Idle Speed
03-001 01/28/2003 Emissions/Engine Controls - MIL ON/DTC P1457 (EVAP)
02-031 09/24/2002 Recall - Ignition Switch Replacement
02-010 06/25/2002 Interior - Seat Back Panel Loose/Detached
NHTSA02V120000 05/01/2002 Recall 02V120000: Ignition Switch Defect
00-095 03/26/2002 Body - Moonroof Seal Squeaks
01-097 02/12/2002 Instruments - Clock Light Inoperative
98-061 11/13/2001 A/T - In-Warranty Exchange Program
99-085 10/26/2001 Recall - DTC P0401 EGR Flow/EGR Port Clogging
01-070 08/07/2001 M/T - 5th Gear Grinds On Upshift
01-029 05/01/2001 Engine Controls - DTC Capture and Downloading
01-003 03/13/2001 Antitheft System - Panic Alarm Sounds By Itself
00-099 12/19/2000 Wiring Terminal - Repair Instructions
00-089 10/31/2000 Supplemental Restraint System - Inspection
98-062 08/22/2000 Trunk - Will Not Open With Remote Transmitter
00-063 08/01/2000 Special Tool - Chassis EAR(TM), Diagnostic Tool
00-018 07/25/2000 MIL ON - DTC's P0171 & P0172 Set
96-012 07/05/2000 A/C - System Performance Testing
99-053 06/27/2000 Immobilizer Key - Key Code Duplicator
99-018 04/11/2000 Required Special Tools And Equipment,
98-019 03/14/2000 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-015 03/14/2000 Audio Unit with CD Player/Changer - Error Codes
00-022 03/07/2000 Torque Converter Oil Seal - Installation Tool
99-063 12/21/1999 Muffler Paint Peeling
97-015 12/07/1999 Service Publications - Availability & Ordering
99-090 11/16/1999 Glove Box Door - Rattle
98-031 11/09/1999 Aftermarket On Board Diagnostic (OBD) || Tester
99-075 10/05/1999 Updated Troubleshooting - DTCs P1456 and P1457
99-038 08/31/1999 MIL ON - DTC P0401 EGR Flow Insufficient
99-066 08/24/1999 MIL ON - P0304 and/or P0306 Codes
99-074 08/24/1999 Troubleshooting DTCs - P1456 & P1457
99-040 08/03/1999 Wheel Bearings, Rear - Noise
99-061 07/27/1999 Ball Joint Removal and Installation Tools
99-030 05/04/1999 Recommended Materials
NHTSA99V069000 04/20/1999 Recall 99V069000: Lower Ball Joint Replacement
98-056 04/01/1999 Fuel Gauge - Readings Are Inaccurate
99-023 03/23/1999 Security System - Activates When Not Armed
98-071 09/22/1998 Power Windows/Door Locks - Do Not Work
98-067 09/01/1998 Moonroof Visor Seal - Splits
98-058 08/11/1998 Radio - Poor Reception/Static on AM Band
98-060 08/11/1998 Rear Seat Back - Lock is Hard to Turn
98-051 08/04/1998 Special Tool Loan Program
98-047 06/09/1998 Ceiling Light - Flickers
98-045 06/01/1998 DTC P1456 & P1457 - Troubleshooting Update
98-043 05/26/1998 Rear Shelf Area - Creaking Noise
98-039 04/28/1998 Brake System - Indicator Lamp Stays ON
98-001 02/23/1998 Engine/Transmission - Hydraulic Lift Truck usage
NHTSA98V018000 02/12/1998 Recall 98V018000: Parking Pawl Modification
98-013 02/09/1998 Headliner/Windshield/Moonroof - Creaking/Popping
97-083 02/09/1998 Paint - Codes/Cross References
NHTSA98V018000 02/06/1998 Recall 98V018000: A/T Park Pawl Modification
98-012 01/26/1998 Accessory Trunk Spoiler - Damages Trunk Paint
97-072 01/12/1998 Brakes - ABS Wheel Sensor Harness Rubs on Wheel
NHTSA97V220000 12/15/1997 Recall 97V220000: Seat Belt Retractor Defect
NHTSA97V220000 12/01/1997 Recall 97V220000: Seat Belt Anchor Defect
97-079 11/17/1997 Rear Doors - Water Leaks To The interior
97-075 11/17/1997 Antitheft - Security System Will Not Function
97-069 10/27/1997 Suspension - Rattle From Rear Stabilizer Bar
97-070 10/27/1997 Body - Wind Noise From the Top of the WIndshield
86-020 05/27/1997 Brakes - Disc Refinishing Procedure
97-027 05/12/1997 Tools - Denso HLD-100 Halogen Leak Detector
97-028 03/31/1997 Body - Minor Paint Finish Repair
97-020 03/10/1997 Tools - New Fuel Pressure Gauge and Replacement Parts
Old Aug 10, 2005 | 10:28 AM
98CoupeV6's Avatar
98CoupeV6
What? Well I guess you won't solve your problem then :dunno:
All you have to do is look through the thread or use the magical internet explorer tool edit-->find. Or the search button for P1457. Not sure why you posted that list.
