Wheel Bearing Help
Old Jul 29, 2005 | 11:30 AM
drooby's Avatar
drooby
Default Wheel Bearing Help
After over discussing the wierd vibration and sounds coming from the car over the past 4 weeks , I am almost at the conclusion that a bad wheel bearing is causing it . I called a shop and got a $340 + tax quote to do this !!
I just spent $475 to get the timing and water pump changed , I cant afford this now .
Long story short - for anyone that has done this before are there any tips on where I should ge the parts and If I can do it myself or not , I do my own oil changed and can do brakes but it takes a while.
Also - anyone know or have detailed - instructions on how to do this job.
Thanks in Advance - I am wondering if the car will get me home today - its really LOUD now and and vibrated like I am gettng a massage!
Old Jul 29, 2005 | 11:35 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
TSB/technical info thread
Old Jul 29, 2005 | 11:43 AM
drooby's Avatar
drooby
Can you post link , did a search on the thread and found nothing>
Old Jul 29, 2005 | 12:26 PM
98CoupeV6's Avatar
98CoupeV6
https://www.honda-acura.net/forums/s...d.php?t=179156
Old Jul 29, 2005 | 01:17 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I just replaced mine in my teg and it is a DIY up to the point where the old bearings need to be pressed out and the new ones pressed in. It shouldn't cost more than $50 to get a machine shop do it for you, but the wheel bearings themselves are pretty expensive.
I would just get the money to pay for it, because even with me removing the knuckles myself and getting the bearings pressed out, it only saved me $100.
Old Jul 29, 2005 | 08:17 PM
tonyhny's Avatar
tonyhny
I have just done this to my 95 accord . The wheel bearing cost $60 from Autuzone but it took me over 4 hours to get everything back together. Taking out the knuckle was a pain. It was a good thing I have a front end tool set. But taking the old bearing out requires some major grinding.....So if I knew it only cost 300 bucks to do it, I would have paid for it.....
Old Jul 30, 2005 | 09:55 PM
Dra4's Avatar
Dra4
Yeah is the labor that is expensive.
Old Jul 30, 2005 | 09:58 PM
Provocateur
On permanent hiatus
Well, I bought OEM bearings because I don't trust Autozone part quality. With my 10% discount at the dealer, they came out to be around $62 a piece. I am sure that an online dealership could sell you OEM bearings for that price and you will know that the quality is top notch.
