Top Dead Center, TIMING, PUMP change
Old Jul 25, 2005 | 08:08 PM
f22b1sedan's Avatar
f22b1sedan
Default Top Dead Center, TIMING, PUMP change
trying to figure out my TDC so that I can set my timing belt up correctly on a 1994 accord ex, motor is an F22b1...Was thinking of doing the screwdriver and the spark plug cylinder deal, but I was wondering if there was a coresponding mark on the crank pully that marks up with the Cam Gear? Any help would be awesome...thanks
nick
Old Jul 25, 2005 | 09:35 PM
AccordVT's Avatar
AccordVT
Ian
On driver's side wheel wel there is a hole in the plastic, stick in a soket the right size for a nut you'll see in there, if you turn it, it turns over your motor, I beileve the timing puley has a dot that lines up with a line/notch on the cylnder head(right next to pulley of course) not sure though, I'm 15, sooo I wouldn't count on it too much but yah I have the same car but I can't remember where the marks are
Old Jul 25, 2005 | 09:38 PM
AccordVT's Avatar
AccordVT
Ian
That will get your valve train all allighned, from there i dunno
Old Jul 25, 2005 | 10:42 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
There should be a red or white mark on the crank pulley when cylinder 1 is TDC. You can use that mark along with the screwdriver trick to make sure.
Just make sure you don't confuse the ignition timing marks with the TDC mark.
Old Jul 26, 2005 | 03:21 AM
f22b1sedan's Avatar
f22b1sedan
I coresponded the arrow(above the crank pully) and the UP on the cam gear, the arrow above the crank pully is in the same location as the one in the fender well, fyi, this motor is out of my car ...arent motor swaps fun ...the frustration is emense...thanks yall
