Water leaking on passenger's legs
Old Jul 25, 2005 | 11:26 AM
led100's Avatar
led100
Default Water leaking on passenger's legs
I have a 1996 Accord EX with VTEC.I had noticed that sometimes there would be a little water dripping on the passenger's side mat when the AC was on.
The past two days though there is a lot more water.
Anyone know why this is happening and if it can be fixed without going to the dealer?
Thanks in advance.
Old Jul 25, 2005 | 01:59 PM
ItsaHonda's Avatar
ItsaHonda
your AC drain hose is clogged. Rather than dripping outside where it should, it is backing up and dripping on the floor. Happed to my 96 too. Some leaves got caught in the hose. I used a coat hanger and cleaned it out, but if you arent sure... any mechanic can do it.
Old Jul 25, 2005 | 04:55 PM
foot's Avatar
foot
I agree. Clogged drain.
Old Jul 26, 2005 | 09:16 AM
led100's Avatar
led100
Thanks for your reply.How can I locate the drain hose?
Old Jul 26, 2005 | 05:37 PM
foot's Avatar
foot
Look. It's under the glove box. It exits through the firewall into the engine compartment then down behind the axles on the subframe.
