Heater stuck on, A/C won't work
SO heres the problem, My heater is stuck on. You can turn the fan off and close the vents, but when you open the vents it's HOT! The A/c light doesn't even come on anymore when I press the button. Any ideas what can be done about this or just a way to unhook the heater for now?
Thanks |
Thanks |
Earlier models had these buttons that people would bang the crap out of and break the welds on the switch. Then AC no worky. I would check for power to and from the switch. Or, start by checking for power to the AC compressor clutch.
you can turn off the heat by closeing the water valve under the hood you, it's on the firewall with a hose going and out with a lever and the cable going inside of the car just move the lever over then the heat is off
I'm havin' this problem too... except that its the cooler air that is on and no heater? 96 accord ex... is there anyway I can fix this?
| All times are GMT -8. The time now is 04:18 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
