replaced AC compressor- blows hot air- help!!!
Old Jul 24, 2005 | 10:07 AM
bigt61's Avatar
bigt61
Default replaced AC compressor- blows hot air- help!!!
i replaced my wifes ac compressor and i replaced all the o-rings in the system. i flushed the ac system with some kind of AC flush from advance. I replaced the receiver drier as well. Then, I hooked all the lines back up, started the AC up, and added freon.
It blows hot air. not a single hint of anything cold. The guage reading stays steady at full for about 20 seconds, then drops down to empty.
I have checked the system for leaks, but found none. Is there a switch or something that I should check? The compressor sycles and comes on, just no cold air blows out.
What should I do? I dont know crap about AC systems.
Thanks guys!
Old Jul 24, 2005 | 10:27 AM
vtec4clyfury's Avatar
vtec4clyfury
Geese!
there could be a leak in your condenser. You might try to find a mechanic that could either check the freon level or add dye to the system. That way if there is a leak an area will be colored with UV dye or whatever color he uses. We've had to do that once or twice.
I know when we check for a leak we put a vaccum on it and see if it holds for awhile or see if we can get it down to 20 or close to 30. I know ac checks if you can find them will only cost you maybe 30-50 dollars depending on where you go. Try that if you keep hitting road blocks.
Old Jul 24, 2005 | 04:49 PM
accordvtec77's Avatar
accordvtec77
when the A/C system is exposed to the atmosphere (opening lines for example), it HAS to be hooked up to an A/C machine that can "vacuum" the system out before you add any freon, otherwise you can add all the freon in existence and it still won't blow cold.
Old Jul 24, 2005 | 07:55 PM
vtec4clyfury
Geese!
i know that, because if you were to open a line while there is freon in it, it will naturally go into the atmosphere which costs quite a bit of money if someone reports it. I meant like vaccum'n out the system and seeing if it would hold a vaccum otherwise it might have a leak. I haven't really fixed a lot of ac's yet so i'm not real sure on this stuff yet.
I start classes for my auto mechanics degree next month...so maybe after a year or two i'll know better ways to answer these. sorry if that sounded retardted.
Old Jul 24, 2005 | 11:26 PM
stereo's Avatar
stereo
if the low side reads into the negitive you wasted your evpansion valve ..
