check engine light and condensor fan
Old Jul 17, 2005 | 08:28 PM
Henry Honda's Avatar
Henry Honda
Default check engine light and condensor fan
My 96 accord ex vtec has a check engine light on. Wiil a bad condensor fan cause this? The fan won't run even when I try to jump it directly from the battery. When is the condensor fan supposed to come on?
Old Jul 17, 2005 | 08:37 PM
DiAbLo3785's Avatar
DiAbLo3785
Working on project CRX Si
could be ur problem but u might wanna check the ECU codes coming from there.
Old Jul 18, 2005 | 03:03 AM
sleezye's Avatar
sleezye
cel is onle emissions related doesnt matter if the cond. fan runs or not both fans should run w\ the eng. started and the a\c compressor on
Old Jul 18, 2005 | 12:13 PM
JimBlake's Avatar
JimBlake
The fan is supposed to be switched based on coolant temperature. Fan switch is in the thermostat housing, with a 2-wire connector. Some earlier years have a 2nd fan switch & a timer module somewhere. I'm not sure whether '96 has the older system...
But I bet the CEL is not related to the bad fan motor. But autoparts chain stores usually will read OBD-2 error codes for free. Get the actual code number 'cause sometimes they get creative with their explanations.
