Air conditioner problem
Old Jul 16, 2005 | 09:01 AM
mini68rt's Avatar
mini68rt
Default Air conditioner problem
I have a 97 Accord 4 cylinder automatic. After I have been driving with the AC on for a little while, I can hear (and feel) the compressor clicking on and off. Once it starts it will continue to click on and off every 2-3 seconds until I turn the AC off. It starts to occur very quickly when I am driving in the city, but it takes a little longer to start happening when I am driving on the highway. I checked the pressure and it was a little high, but not too high, so I let some of the refrigerant out to get it into the correct range and it is still occuring.
Also, the refrigerant I let out had a greenish tint to it. Is it supposed to?
Anyone know what might be causing this? Any help would be appreciated.
Old Jul 16, 2005 | 06:23 PM
azianstylez's Avatar
azianstylez
isn't it illegal to let refrigerant leak???
Old Jul 16, 2005 | 07:16 PM
motoguy128's Avatar
motoguy128
Yes it is. Considered as bad as dumping oil or antifreeze.
The green tint is a dye that they put into the lubricating oil in the refrigerant so you can visually detect leaks. It glows under a blacklight.
As for your problem... There could be a problem with the compressor or a there is a pugged line and pressure is building up and the compressor is tripping out when it's overloaded.
Old Jul 17, 2005 | 06:53 AM
BNaccord2k1's Avatar
BNaccord2k1
It's only illegal if you are a licensed mechanic.
Old Jul 18, 2005 | 01:39 PM
honda guy's Avatar
honda guy
Yeah keep telling yourself that. And you don't need to be liscensed to be a Mechanic.
It still may be overcharged. The turning on and off usually is a signall that there is to much of a charge in it. also followed by low idle.
