Check Engine Light ON after installing intake
Old Jul 9, 2005 | 11:38 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
Default Check Engine Light ON after installing intake
I have a 7th generation Accord v6 and right after intalling my Short RAM intake, the check engine light is ON, Any suggestions?
Thanks for all the help.
Old Jul 10, 2005 | 12:30 AM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
reset the ECU by disconnecting the battery for a few minutes.... tht should help
Old Jul 10, 2005 | 10:02 AM
foot's Avatar
foot
Read the code. It will help tell you what is wrong.
Old Jul 10, 2005 | 10:21 AM
shonnv's Avatar
shonnv
7th Gen Coupe V6
What code and where can I find it?
Old Jul 10, 2005 | 02:17 PM
VPUPPY's Avatar
VPUPPY
the check engine light usually means that a code has been stored in the ECU for the engine. the code corresponds to a particular system in the engine that has failed. for example, if a o2 sensor went bad, the ECU would store a code dealing with the o2 sensor or its subsystem. now, to get the code, you should be able to goto autozone and have them read the code for you. they have a code scanner that reads the code from the ECU.
