Newbee: Sticking caliper / piston
Old Jun 26, 2005 | 07:40 AM
mcwb01's Avatar
mcwb01
Default Newbee: Sticking caliper / piston
I have a 94 accord and i noticed that the back drivers side pad is worn down about 60% more than the back passenger side. I belive the caliper / piston is sticking. Could anyone tell me how to service this to stop the sticking ? Is it as simple as applying some grease / wd40 to a certain area ?
Old Jun 26, 2005 | 07:57 AM
foot's Avatar
foot
Depending on the caliper design, check the pins that the caliper slide on. Sometimes if they aren't greased this can happen. The pins are the two that bolt the floating portion of the caliper to the caliper mounting brachet.
Old Jun 26, 2005 | 07:23 PM
Cosmo M3's Avatar
Cosmo M3
Lurker
^:werd:
after that, clean off the rotors with brake cleaner spray. You should bleed the brakes too while you're at it.
Old Jun 27, 2005 | 09:21 AM
mcwb01's Avatar
mcwb01
Thanks for the help. We'll see if this fixed it. If not I will go back and replace the caliper.
Old Jun 27, 2005 | 07:55 PM
foot's Avatar
foot
There can also be restrictions in the lines causing one caliper to instead of stick, not activate, making the other caliper SEEM like its sticking and wearing prematurely. Most likely, the pins are dry.
