electrical problem: Brake light/Horn/Cruise Control
Old Jun 26, 2005 | 06:54 AM
ct976's Avatar
ct976
Default electrical problem: Brake light/Horn/Cruise Control
98 Accord 4cyl
Here is the problem:
1)I changed the battery (the procedure was correct, did not reverse terminals and there shouldn't be damage.)
2) Everything else works. but I noticed brake lights were out, fuse was burnt. changed the fuse in engine bay. Brake lights work
3) pressed horn, horn muffled for 1/2 second and went out. Cruise control stopped working, Brake Lights out again
4) Checked all plugs and horn relay. all connections are fine.
*Noticed that the STOP(Brake) fuse which I just changed is burnt again.
*Also tested that No Power is going to the horn relay terminal.
So, the problem occurs when I use the horn. It blows the fuse. using the brake lights only will not burn the fuse.
What's going on?? It appears those 3 things are related to that single 20A fuse under the hood, so i assume its the same fuse.
- Is the terminal supplying power to the 20A STOP light fuse overloaded? by what?
- Do i have a bad connection at the horn that keeps blowing that fuse?????
Old Jun 26, 2005 | 07:59 AM
foot's Avatar
foot
You've got a short circuit.
Old Jun 26, 2005 | 09:47 AM
stereo's Avatar
stereo
sounds like your horn is shorting out . unplug the horns replace the fuse push the horn button if the fuse doesn't blow you know what your problem is.
Old Jun 26, 2005 | 11:41 AM
ct976's Avatar
ct976
yes, im pretty sure there is something wrong with the horn circuit. but where? i tried and it is not the power supply connectors to the horn. where else can it short?
Old Jun 29, 2005 | 06:22 PM
ct976's Avatar
ct976
bump for more info :?:
Old Jun 29, 2005 | 06:38 PM
foot's Avatar
foot
If the horn uses a coil then I'd say the winding is shorted. A short in a coil will result in less resistance and more current flow, blowing the fuse. I don't even know what type of horn these use, though.
Old Jul 3, 2005 | 02:49 PM
ct976's Avatar
ct976
you are right. one of the horn's is creating a short. i took the bad one off and it works. just ordered a replacement from honda! thanks!
Old Jul 3, 2005 | 07:01 PM
foot's Avatar
foot
Sweet.
