Speaker Installation question.
Old Jun 16, 2005 | 11:59 AM
hawkdsp's Avatar
hawkdsp
Default Speaker Installation question.
I'm installing new rear deck speakers into my recently aquired 97 Accord SE and I have four different color leads, blue and gray on the driver side and orange and brown on the passenger side. Does anyone know which of these are positive and negative?
Old Jun 16, 2005 | 12:19 PM
foot's Avatar
foot
Use a volt meter. If the volt reading is positive then the positive and negative leads on the meter are on the corrosponding wires. If teh voltage reading is negative, the red lead is on the negative wire and the black lead is on the positive wire.
Old Jun 16, 2005 | 12:20 PM
hawkdsp's Avatar
hawkdsp
thanks
Old Jun 18, 2005 | 04:54 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Originally Posted by hawkdsp
thanks
Do the battery trick,.. it's much easier.
Any batt will do.
Connect both leads to the pos/neg on the battery.
If the speaker sucks in,... then the polarity is wrong.
If it moves out,.. the polarity is correct.
Old Jun 18, 2005 | 11:07 PM
iobidder's Avatar
iobidder
Registered Abuser
Any batt will do.
Man, old school trick! I remember doing that!
Old Jun 19, 2005 | 02:10 AM
Nirvanaspartan's Avatar
Nirvanaspartan
:nervous: :nervous: :nervous: :huh: :ugh: :dunno: what if you dont connect the speakers to the right positive and negitive wire and some how you get them cross because i installed 6x9's and i wasnt sure what wire was to which so i teasted them out by which one made the speakers work and both ways worked so i just connected them without being sure if it was the wire to negitive and positive?:nervous: :nervous: :nervous: :huh: :ugh: :dunno:
Old Jun 19, 2005 | 08:11 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Then you do the cheap battery trick like I said in the previous post.
Oh,.. and use some commas and periods next time..
Old Jun 19, 2005 | 11:04 PM
Nirvanaspartan
ok, but what happens if i dont? would they mess up or what? blow out, catch fire?come on give me feedback and not a grammar lesson,
:joshers: :joshers: :joshers: :joshers: :joshers: :joshers: :joshers: :joshers: :joshers:
Old Jun 20, 2005 | 04:27 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
In your case,.. you need both!
If you have them hooked up wrong, then you're probably not getting the full potential quality/ sound of the speaker.
For instance, if a sub is hooked up backwards,.. then the base cancels out, meaning they are out of phase.
