H22a questions
Old May 23, 2005 | 06:17 PM
CL1accord's Avatar
CL1accord
Default H22a questions
wondering if the H22a head will fit on the stock F23a1 block with or without modifications, is it the same bolt pattern bigger or smaller.
Old May 23, 2005 | 10:29 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
No, it will not fit.
Old May 24, 2005 | 11:38 AM
H-Accord-22's Avatar
H-Accord-22
Duh
If I remember correctly, then you can do it. Go to Honda-tech.com. There are couple guys who're doing the Frankenstein and seems to run fine with minor modification.
Old May 24, 2005 | 11:47 AM
h22accord's Avatar
h22accord
155mph and still climbing
yes it will work. It requires blocking off a bunch of stuff. Its more cost effective to just do the engine swap than to do the head swap unless you just so happend to have all of the things laying around to do it with.
Old May 24, 2005 | 02:19 PM
2legit2quit's Avatar
2legit2quit
You Big Dummy
I know of H23 with H22 head, but never heard of F23 with it done. Regardless, an ful H22 swap is alot better, especially longevity wise.
Old May 25, 2005 | 12:05 PM
CL1accord's Avatar
CL1accord
wont it run cheaper since it is only the h22 or h23 head to buy instead of the whole motor and just had a question will the head bolt right up to the block and what type of modifications are listed thanks.
Old May 25, 2005 | 06:38 PM
h22accord's Avatar
h22accord
like i said before unless you have all of the parts laying around it would be much easier and probably cheaper to just do the whole swap. More than likly you will have the same amount of money in either or, but IMO the full engine swap would last longer than just a head swap and would have many less problems. But if you want information from someone who has already done the swap here is the link H22A head swap. Also read the whole thread not just the first post. There is alot more information in it.
Old May 25, 2005 | 09:58 PM
Provocateur
On permanent hiatus
You proved me wrong. I didn't know you could interchange unrelated engine parts like that or better yet, convert a SOHC block to run a DOHC head.
