Indiglo Lights
Old Mar 9, 2005 | 04:13 PM
azianstylez's Avatar
azianstylez
Default Indiglo Lights
I have browsing and found my threads concerning the risk of installing indilglo face. On my old acura, i installed a cf blue indiglo face, and there was no problem with it. Do u guys recommend gettin them.??
Old Mar 10, 2005 | 06:28 AM
blacknight07601's Avatar
blacknight07601
As long as they're installed properly they should be fine
Old Mar 10, 2005 | 07:01 AM
JL95AccorD's Avatar
JL95AccorD
LMAO... Please tell me that your avatar is a guy dressed as a female licking a turbo.
Old Mar 10, 2005 | 07:03 AM
blacknight07601
LOL, nah. It's a girl. The pic didn't come out that great cause I had to shrink it down to 90 x 90 pixels
Old Mar 10, 2005 | 07:39 AM
Cosmo M3's Avatar
Cosmo M3
Lurker
LMFAO....
anyways, if its installed correctly (like the gauges don't interfere with the needles moving around) then you should be straight.
Old Mar 10, 2005 | 08:04 AM
Intrepid241's Avatar
Intrepid241
Indiglo gagues work great, if you know what you're doing.
Old Mar 10, 2005 | 03:28 PM
azianstylez
any instruction on how to install them?? I installed one on my acura legend!! but im not sure if its gunna be the same.
Old Mar 10, 2005 | 03:52 PM
blacknight07601
Well, there's a couple of ways. Some companies reccomend you take off the old gauges and needles and replace them with the new gauges and put the needles back on. Those are old indiglow gauges that tends to put out heat. Plus, it's a pain to put the needles back in the correct spot. Especially the speedo needle. THe tach, temp, & fuel needles are a little easier. You can remember the correct spot for those during normal operating temperature. Other companies reccomend you just slide the gauges over the needles and on top of the stock gauges. There are a few reasons for this
1) It's much simplier
2) They don't heat up as much as the older ones
3)You don't have to remove the needles
After that, everything is pretty easy. Just connect the gauges to the supplied power supply, and connect the two wires from the power supply (pos/neg) to the proper source. When I connected mine, I simply ran the positive to a spot in the fuse box that is activated when the key is in the "ON" position. then simply ground the negative and you're done. Here's a few pics of mine
